DFPlayer Mini baud rate selection
Account cancelled 2015-12-06 09:19:19 4608 Views5 Replies The DFPlayer Mini manual says "Baud rate adjustable (default baud rate is 9600)". How do you change the baud rate? I couldn't find any commands to change the baud rate.
2018-06-28 01:16:14 i do not understand the solution, how this code can change the baud rate of dfplayer ??
bondo2a31193
bondo2a31193 2016-01-13 18:40:57 Hello budiwahyunugroho92
Sorry your project isn't working! What baud rate are you using? Can you show me the connections you have?
Maht
Maht 2016-01-12 20:11:26 I do not know what happened with my project .. I've been followed the tutorial ... but the result is like this.
budiwahyunugroho92
budiwahyunugroho92 2015-12-11 19:02:08 Hi Kongsimon22,
Apologies for the delay in replying. It seems that the baud rate can be changed.
Try the following lines of code in your sketch:
You can also try editing the "Serial.begin (9600);" lines in your sketch to reflect a different baud rate, e.g. 115200.
If you're still having problems come back and let us know.
Maht
void h_send_func () {
for (int i=0; i<10; i++) {
_hardware_serial->write (send_buf[i]);
void s_send_func () {
_software_serial->write (send_buf[i]);
/ oid mp3_set_serial (HardwareSerial *theSerial) {
void mp3_set_serial (HardwareSerial &theSerial) {
_hardware_serial = &theSerial;
send_func = h_send_func;
void mp3_set_serial (SoftwareSerial &theSerial) {
_software_serial = &theSerial;
send_func = s_send_func;
Maht
