DFR0342 versus DFR0222
userHead john 2016-03-03 05:56:14 2942 Views3 Replies
The folks at mydooropener.com (garage door opener solution) suggest using the XBoard Relay (DFR0222) as the main part of their solution. I am hoping to find a solution that uses Power Over Ethernet rather than the DFR0222 AC adapter. I am hoping that the DFR0342 (an Ethernet board that incorporates POE) can be substituted for the DFR0222. I am hoping that someone will take a quick look at the two boards and tell me if the mydooropener.com software is likely to work on both boards and if controlling a garage door is possible with the DFR0342. I have asked the same question on the mydooropener.com forum and have yet to get a response.
https://www.dfrobot.com/wiki/index.php/X-Board_Relay(SKU:DFR0222)
https://www.dfrobot.com/wiki/index.php?title=W5500_Ethernet_with_POE_Mainboard_SKU:_DFR0342
2016-03-07 23:00:31 Sorry, I made a typo error, I mean relay module
https://www.dfrobot.com/index.php?route= ... arch=relay
userHeadPic Leff
2016-03-06 21:42:57 Leff, thanks for helping me. You mentioned a delay module. I tried to find that part mentioned on the product description pages but could not see it. I want to figure out a way to make the board employing power over Ethernet work for me and if I need a delay module for the DFR0432 I'd like to find it and figure out how to install it. I'll check the DFRobot website for delay modules. Do you have a recommendation? userHeadPic john
2016-03-04 00:50:02 Hi John,
Both the cards use WIZnet W**** series chip, so it should be compatible. Besides, if you use https://www.dfrobot.com/wiki/index.php?t ... U:_DFR0342, you have to buy another delay module.
userHeadPic Leff
