DFPlayer simultaneous usage
userHead anonymous 2016-03-03 06:17:23 16067 Views19 Replies
If I use the dfplayer can I play sound effects with the arduino uno or mega, while simultaneously moving servo and stepper motors without interference?
2017-03-15 09:36:10 Hi there, I just registered while searching for answers to the DFplayer.
I actually have the same task, getting a gate crossing working for the model railroad 8-)
My approach is a bit different from the sketch, but basically similar, trying to play a loop (bell ring) while a servo is shutting the gates and a relay powering an external blinking module for the many LED's in action.
I can get the dfplayer to work w/o problems alone, using the wiki sample code.
I can get the servo and relay working all controlled by a single button.
But the moment I try to integrate the DFplayer into the sketch, I run into problems.
Example:
in the void setup() section I have a series of setup syntax. If I add myDFPlayer.volume(10); and myDFPlayer.play(1); at the end of the setup section, the NANO I use hangs! The built in LED on Pin 30 starts blinking and no reaction on the rest button on the board. I need to upload another sketch to bring the NANO back to life. If I add myDFPlayer.volume(10); and myDFPlayer.play(1); at the beginning of the setup, I don't run into this problem. However, the sketch gets stuck later hanging somewhere. I tried so many possibilities. I will upload the sketch I use later, currently not at home.
@ mnrk:
At the current version of my sketch, the servo is not yet included! And it doesn't work with DFplayer! So it has nothing to do with incompatibility of the servo and DFplayer library.
userHeadPic liquidfantasy
Example:
@ mnrk:
2017-03-15 05:35:27 I did the dfplayer initializationot and that was working. So that isn't it. Any other thoughts? userHeadPic mnrk
2017-03-15 02:25:55 Hi
Please refer to the wiki sample code to do the dfplayer initialization, if the initialization is not successful, which is possible to result the problem I think.
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
mySoftwareSerial.begin(9600);
Serial.begin(115200);
Serial.println();
Serial.println(F("DFRobot DFPlayer Mini Demo"));
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
if (!myDFPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with mp3.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while(true);
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.volume(10); //Set volume value. From 0 to 30
myDFPlayer.play(1); //Play the first mp3
userHeadPic Wendy.Hu
Serial.println();
while(true);
2017-03-14 15:39:26 Correction: I figured out why nothing was playing...I didn't have the following lines in the setup() section:
if (!myPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with mp3.
while (true);
BUT...when I have the myservoX.attach(N); lines and myservoX.write(pos); lines un-commented, the servos still go crazy and spastic.
It seems to me that there is something not compatible with the Servo library and either the SoftwareSerial library or the DFRobotDFPlayerMin library.
Can anyone a bit more knowledgeable in that department help me figure this out?
Thanks.
userHeadPic mnrk
while (true);
Thanks.
userHeadPic mnrk
2017-03-14 13:50:48 That didn't work. I even tried to remove the 'if' statements and only included one of the 'myPlayer.play(1);' commands and that is where things now just don't do anything (no sound and servos don't move). If I comment out the 'myPlayer.play(1);' line then the servos sweep. Is there something that is interfering between the Servo, DFRobotDFPlayerMini, and/or SoftwareSerial libraries? Am I using the correct pins on the Arduino mini pro (10 as RX to Pin3 on DFPlayer, 11 as TX to Pin2 on DFPlayer, 5 as signal to servo1, 6 as signal to servo2)?
#include <Servo.h>
#include <DFRobotDFPlayerMini.h>
#include <SoftwareSerial.h>
DFRobotDFPlayerMini myPlayer;
Servo myservo1; // create servo object to control a servo
Servo myservo2;
int buusyPin = 3; //busy pin from dfplayer
int pos = 0; // variable to store the servo position
myservo1.attach(5);
myservo2.attach(6);
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
myPlayer.play(1);
myservo1.write(pos); // tell servo to go to position in variable 'pos'
myservo2.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
userHeadPic mnrk
#include <Servo.h>
Servo myservo2;
myservo1.attach(5);
myservo2.attach(6);
myPlayer.play(1);
userHeadPic mnrk
2017-03-14 00:17:19 Hi
Did you try to change the code as below to try again?
#include <Servo.h>
Servo myservo2;
myservo1.attach(5);
myservo2.attach(6);
if (digitalRead(buusyPin) == HIGH) { // if DFPlayer is done playing the sound, play it again
myPlayer.play(1);
for (pos = 180; pos >= 0; pos -= 8) { // goes from 180 degrees to 0 degrees
myPlayer.play(1);
#include <Servo.h>
Servo myservo2;
myservo1.attach(5);
myservo2.attach(6);
myPlayer.play(1);
myPlayer.play(1);
2017-03-13 05:32:00 Forgot to say that I'm using a mini pro for this project. userHeadPic mnrk
2017-03-12 16:46:20 I tried to just drop some code in and the servos went crazy/spastic.
I'm trying to have some model railroad crossing gates close using servos while having a bell sound as the gates go down and up. What have I missed... This is the code that I'm testing with [modification of the servo sweep example]:
[code]
#include <Servo.h>
Servo myservo2;
myservo1.attach(5);
myservo2.attach(6);
myPlayer.play(1);
myPlayer.play(1);
[/code]
I'm using Arduino IDE 1.8.1 and the DFRobotDFPlayerMini 1.0.1 library
userHeadPic mnrk
[code]
#include <Servo.h>
Servo myservo2;
myservo1.attach(5);
myservo2.attach(6);
myPlayer.play(1);
myPlayer.play(1);
[/code]
userHeadPic mnrk
2016-03-04 00:52:26 Hi sekramer10,
Should be no problem, to play some music just need to drop a line of relative command, after that, the DFplayer will play music, the code will proceed on the servo. stepper things... then.
userHeadPic Leff
userHeadPic Leff
2016-03-03 06:17:23 If I use the dfplayer can I play sound effects with the arduino uno or mega, while simultaneously moving servo and stepper motors without interference?
userHeadPic anonymous
