My samsung galaxy note 2 can't find my Bluno Bluetooth
userHead agung911 2014-05-26 20:01:57 13789 Views19 Replies
Hi There... :D
I wish anyone can help me
My galaxy note 2 firmware is 4.4.2 and My Bluno Frimware is v1.8
I have read and try Bluno Basic Demo tutorial and still it can't solve this, my samsung device can't find my blune bluetooth.
Anyone can help me?
Thank's and sorry for my bad english... I'm from indonesia...
I wish any basic tutorial for me with picture for connecting between my device.
Thank's again...
2014-05-27 00:00:26 Some times I search it when AT mode...
Not found...
And I also Seach It in Normal Mode...
Still Not Found...
I Think it's because AT Mode is not configured well...
Any suggest Mr. Grey and Mr. Visual XL???
userHeadPic agung911
Not found...
Still Not Found...
2014-05-26 23:53:20 Agung,
Did you exist the AT mode, when you search the the device?
userHeadPic Grey.CC
userHeadPic Grey.CC
2014-05-26 23:22:06 AT+BIND=
REPLY IS "0x000000000000"
AT+MAC=
REPLY IS "0xD03972A03F8C"
AT+MAC=
2014-05-26 23:14:10
Code: Select all
AT+BIND=?
AT+MAC=?
Is there any values returned by the above commands?
userHeadPic visualxl
2014-05-26 23:14:10
Code: Select all
AT+BIND=?
AT+MAC=?
2014-05-26 23:00:48 I Have Give it a name...
AT+NAME=BigBaby...
Still Not Detected...
I have downloaded Bluetooth LE scanner too
after I scan it say "no data"...
AT+NAME=BigBaby...
2014-05-26 22:47:18 Agung, give it a name or something, then try again.
Code: Select all
AT+NAME=BabyBoo
And also try on different app, like "Bluetooth LE Scanner".
Code: Select all
AT+NAME=BabyBoo
2014-05-26 22:30:59 Still not detected  :(  :'(
Thanks Grey...
I Have Download BLE Sample App for Android... but It still not detected...
Thanks Grey...
2014-05-26 22:05:09 Welcome Agung, and thank you visualxl.
Yeah, visualxl is right, when Bluno is central, it could only connect to DFRobot BLUNO or ble link.
Please try the default setting.
Code: Select all
AT+SETTING=DEFAULT
. And it also need Android  app to connect to Bluno.
userHeadPic Grey.CC
Code: Select all
AT+SETTING=DEFAULT
userHeadPic Grey.CC
2014-05-26 21:29:43 Hey, don't worry about your English. Many of us don't speak good English too.
Are you sure that your Bluetooth is on on your Note 2?
There should not be anything to configure for the BLUNO to be detected since it is set to peripheral by default.. Unless if you change it to CENTRAL accidentally. Or if the BLUNO has been BINDED to another BLUNO.
Try this on your BLUNO.
Code: Select all
AT+SETTING=DEFPERIPHERAL
Screenshot and post the response of your Serial Monitor if you still cannot detect.
Code: Select all
2014-05-26 20:01:57 Hi There... :D
Anyone can help me?
Thank's again...
