apc220 + java
scofielcl 2014-05-30 00:30:32 4801 Views4 Replies Hello . I want to read from the com port bytes , but the program does not respond.
I am using apc220 (radio module). and arduino uno. http://fritzing.org/projects/wireless-a ... ith-apc220
java programm :
I need help.
java programm :
Read with arduino IDE or c# correct.
package com_port;
import jssc.SerialPort;
import jssc.SerialPortEvent;
import jssc.SerialPortEventListener;
import jssc.SerialPortException;
public class Com_port {
private static SerialPort serialPort;
public static void main(String[] args) {
serialPort = new SerialPort("COM7");
try {
serialPort.openPort();
serialPort.setParams(SerialPort.BAUDRATE_9600,
SerialPort.DATABITS_8,
SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
serialPort.setFlowControlMode(SerialPort.FLOWCONTROL_RTSCTS_IN |
SerialPort.FLOWCONTROL_RTSCTS_OUT);
serialPort.addEventListener(new PortReader(), SerialPort.MASK_RXCHAR);
catch (SerialPortException ex) {
System.out.println(ex);
private static class PortReader implements SerialPortEventListener {
public void serialEvent(SerialPortEvent event) {
if(event.isRXCHAR() && event.getEventValue() > 0){
try {
byte[] data = serialPort.readBytes();
System.out.println(data[0]);
I need help.
2014-06-05 23:21:33 [quote="scofielcl"]
https://code.google.com/p/java-simple-s ... loads/list
I am thinking , necessary to establish specific settings port.
[/quote]
Looks interesting, but I don't speak Java
are you planning on putting it on a web?
I'd like to try this
Jose
[/quote]
Jose 2014-05-30 22:25:46 Hello Grey.
Setting for apc220 is correct , exactly.
I do read and write with apc200 use c# and arduino IDE.
Hello Jose.
scofielcl
Hello Jose.
scofielcl 2014-05-30 21:55:49 hey,
Seems that you require a library for this project.
Where did you get this library from ?
Cheers^^
Jose
Cheers^^
Jose 2014-05-30 19:26:13 Welcome scofielcl,
I am not familiar with Java, but I thinks it is a good idea to configure APC220 parameter first.
Here is APC220 wiki page.
After the configuration, it is better to test communication first.
Grey.CC
Grey.CC
