Problem with rotary encoders and attachInterrupts
Account cancelled 2016-04-05 07:56:59 2619 Views1 Replies Hi ! I have a strange behaviour with rotary encoders. It's already detailed on Arduino forum :
https://forum.arduino.cc/index.php?topic=391250.0
Any idea ?
Thanks !
Any idea ?
Thanks !
2016-04-06 02:19:48 HI reseaux,
I read your link, have you tried:
1) To make the Arduino board (328 based) and motor&encoder to be at the same ground (same GND)?
2) The code given by dlloyd to deal with the noise effect.
And here is another very good software debounce.
Leff
#define LEFT 0
#define RIGHT 1
const unsigned long interval = 200; //interrupt debounce interval (µs)
volatile unsigned long timeNow[2] = {0, 0};
volatile unsigned long timePrev[2] = {0, 0};
volatile long coder[2] = {0, 0};
volatile int lastSpeed[2] = {0, 0};
Serial.begin(9600); //init the Serial port to print the data
attachInterrupt(LEFT, LwheelSpeed, CHANGE); //init the interrupt mode for the digital pin 2
attachInterrupt(RIGHT, RwheelSpeed, CHANGE); //init the interrupt mode for the digital pin 3
static unsigned long timer = 0; //print manager timer
if (millis() - timer > 100) {
Serial.print("Coder value: ");
Serial.print(coder[LEFT]);
Serial.print("[Left Wheel] ");
Serial.print(coder[RIGHT]);
Serial.println("[Right Wheel]");
lastSpeed[LEFT] = coder[LEFT]; //record the latest speed value
lastSpeed[RIGHT] = coder[RIGHT];
timer = millis();
void LwheelSpeed() {
timeNow[LEFT] = micros();
if (timeNow[LEFT] - timePrev[LEFT] > interval) {
timePrev[LEFT] += interval;
coder[LEFT] ++; //count the left wheel encoder interrupts
void RwheelSpeed() {
timeNow[RIGHT] = micros();
if (timeNow[RIGHT] - timePrev[RIGHT] > interval) {
timePrev[RIGHT] += interval;
coder[RIGHT] ++; //count the right wheel encoder interrupts
byte LED = 13;
byte BUTTON = 3;
void setup(void)
pinMode(LED,OUTPUT);
pinMode(BUTTON,INPUT_PULLUP);
digitalWrite(LED,LOW);
void loop(void)
static unsigned long timepoint = millis();
static byte count = 0;
if(millis()-timepoint > 10)
if(digitalRead(BUTTON)) count = 0;
if( (count<100) && (++count==10) )
digitalWrite(LED, digitalRead(LED)^1);
Leff
