Temperature Sensor Stability Performance
andy.hegedus 2016-04-12 17:24:46 5363 Views6 Replies Hi,
I have a Galileo Gen 2 and I have connected an LM35 based temperature sensor from DFRobot.
I have connected it to A5 on an I/O Expansion shield also from DFRobot and I am using an external power supply to power the Galileo. I checked the power at pins with a dvm and get 4.95-4.96V and it is very steady.
I have a very simple sketch to read the values and send them to the serial monitor. I try this in 10 bit and 12 bit resolution. The values and the range seem quite large and the noise signal is not a normal distribution, more random. The values scale exactly as anticipated in going from 10 bit to 12 bit.
the temperature conversion is 0.010mV/C so these ranges are quite large (70-35=35). 35/1024*5V = 0.17V which translates to 17 degrees. The sensor was just sitting in air next to me.
Does any one have data to compare? When I look online most discussion refers to uncontrolled Vcc but I measured it and it seems stable.
Temperature Readings.png (209.21 KiB) Downloaded 1215 times
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
Serial.begin(9600);
analogReadResolution(12);
// the loop routine runs over and over again forever:
// read the input on analog pin 5:
int sensorValue = analogRead(A5);
// print out the value you read:
Serial.println(sensorValue);
delay(200); // delay in between reads for stability
Great to know it is not a defective one. Thanks for your follow-up.
Leff Plan going forward is to give up on the Intel Galileo board and stick with the R3.
andy.hegedus If it is within warranty, please submit a RMA to DFRobot through Product Returns pageattaching with this post link in the blank of "Faulty or other details", thank you!
Leff For complete analysis and additional data you can review this https://communities.intel.com/thread/100999 from the Intel Galileo forum site.
andy.hegedus
andy.hegedus May I confirm how it became unsteady? I can't tell much according to "I have a very simple sketch to read the values and send them to the serial monitor. I try this in 10 bit and 12 bit resolution. " , as you told it was working alright, how it became abnormal?
Leff
