GPS/GPRS/GSM Module V3.0, "stuck at Lat:" Broken?!?!
MMAB 2014-07-22 20:47:58 4323 Views3 Replies Hi there,
I am having a problem with retrieving the Geolocation of my system. I am using Arduino MEGA 250 as my main board, i am also using the following ports 12,11,10,9,8,7 for my LCD display, the jumpers are still on the pins and i am using them to retrieve the location. I have been able to retrieve UTC successfully, but when the system gets to the point of receiving the Lat: it just stopes..... I tried going outside, to the roof i even took the system with me to another country and tested it, but nothing happened. ??? At first i used to get ovf. as an output.... but now NOTHING!!!! :-\
I am not sure why is this happening with me, there isn't anything with the power supply, because i can send, receive SMS's and even make phone calls.
I used the exact same code provided, to test it.. NOTHING!!
Thanks!!!// Product name: GPS/GPRS/GSM Module V3.0
// include the library code:
#include <LiquidCrystal.h>
double lon;
double UTCP;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 10, 9, 8, 7);
double Datatransfer(char *data_buf,char num)//convert the data to the float type
{ //*data_buf?the data array
double temp=0.0; //the number of the right of a decimal point
unsigned char i,j;
if(data_buf[0]=='-')
i=1;
//process the data array
while(data_buf[i]!='.')
temp=temp*10+(data_buf[i++]-0x30);
for(j=0;j<num;j++)
temp=temp*10+(data_buf[++i]-0x30);
//convert the int type to the float type
for(j=0;j<num;j++)
temp=temp/10;
//convert to the negative numbe
temp=0-temp;
else//for the positive number
i=0;
for(j=0;j<num;j++)
for(j=0;j<num;j++)
temp=temp/10 ;
return temp;
char ID()//Match the ID commands
char i=0;
char value[6]={
'$','G','P','G','G','A' };//match the gps protocol
char val[6]={
'0','0','0','0','0','0' };
while(1)
if(Serial.available())
val[i] = Serial.read();//get the data from the serial interface
if(val[i]==value[i]) //Match the protocol
i++;
if(i==6)
i=0;
return 1;//break out after get the command
else
i=0;
void comma(char num)//get ','
char val;
char count=0;//count the number of ','
while(1)
val = Serial.read();
if(val==',')
count++;
if(count==num)//if the command is right, run return
return;
void UTC()//get the UTC data -- the time
char i;
char time[9]={
'0','0','0','0','0','0','0','0','0'
double t=0.0;
if( ID())//check ID
comma(1);//remove 1 ','
//get the datas after headers
while(1)
time[i] = Serial.read();
i++;
if(i==9)
i=0;
t=Datatransfer(time,2);//convert data
t=t+30000.00;//convert to the chinese time GMT+8 Time zone
Serial.println(t);//Print data
UTCP = t;
return;
void latitude()//get latitude
char i;
char lat[10]={
'0','0','0','0','0','0','0','0','0','0'
if( ID())
comma(2);
while(1)
lat[i] = Serial.read();
i++;
if(i==10)
i=0;
Serial.println(Datatransfer(lat,5),5);//print latitude
lon = (Datatransfer(lat,5),5);
return;
void lat_dir()//get dimensions
char i=0,val;
if( ID())
comma(3);
while(1)
Serial.write(val);
Serial.println();
i++;
if(i==1)
i=0;
return;
void longitude()//get longitude
char i;
char lon[11]={
'0','0','0','0','0','0','0','0','0','0','0'
if( ID())
comma(4);
while(1)
lon[i] = Serial.read();
i++;
if(i==11)
i=0;
Serial.println(Datatransfer(lon,5),5);
return;
void lon_dir()//get direction data
char i=0,val;
if( ID())
comma(5);
while(1)
Serial.write(val); //Serial.println(val,BYTE);
Serial.println();
i++;
if(i==1)
i=0;
return;
void altitude()//get altitude data
char i,flag=0;
char alt[8]={
if( ID())
comma(9);
while(1)
alt[i] = Serial.read();
if(alt[i]==',')
flag=1;
else
i++;
if(flag)
i=0;
Serial.println(Datatransfer(alt,1),1);//print altitude data
//double s = (Datatransfer(alt,1),1);
//lcd.setCursor(0, 1);
//lcd.print(s);
return;
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
pinMode(3,OUTPUT);//The default digital driver pins for the GSM and GPS mode
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
digitalWrite(5,HIGH);
delay(1500);
digitalWrite(5,LOW);
digitalWrite(3,LOW);//Enable GSM mode
digitalWrite(4,HIGH);//Disable GPS mode
delay(2000);
Serial.begin(9600);
delay(5000);//GPS ready
Serial.println("AT");
delay(2000);
//turn on GPS power supply
Serial.println("AT+CGPSPWR=1");
delay(1000);
//reset GPS in autonomy mode
Serial.println("AT+CGPSRST=1");
delay(1000);
digitalWrite(4,LOW);//Enable GPS mode
digitalWrite(3,HIGH);//Disable GSM mode
delay(2000);
Serial.println("$GPGGA statement information: ");
while(1)
Serial.print("UTC:");
UTC();
lcd.setCursor(0, 0);
lcd.print(UTCP);
Serial.print("Lat:");
latitude();
lcd.print(lon);
Serial.print("Dir:");
lat_dir();
Serial.print("Lon:");
longitude();
lon_dir();
Serial.print("Alt:");
altitude();
delay (1000);
Serial.println(' ');
lcd.print(UTCP);
lcd.print(lon);
2014-08-08 18:56:41 Smart phone is different to these kind of module.
It will using AGPS to locate your approximate position first, and then it will using GPS to confirm your accurate location.
Anyway, did you try the wiki sample code? It looks very similar to yours.
Grey.CC
Grey.CC 2014-08-08 10:51:11 Sorry for the late reply,
I am using a [6] double A batteries back, which gives me 9 volts in total... according to the online wiki it is more than enough to power up the module .... i am not sure what is the problem.. i even tried using the GPS in my phone, to make sure that it is not a signal issue.... and it worked perfectly. However, using this module is just proven to be a long and stressful wait.
Thanks!
MMAB
Thanks!
MMAB 2014-07-23 00:53:49 Hello MMAB,
I solved the same problem by going outdoors. From other reports, same fix. So it is most likely a problem with the GPS signal. Do you have a clear picture of the module? And provide specific details of your hardware. Saying that the power supply has no problem does not clarify anything. How are you wiring it? what are the specs of the power supply?
Jose
Jose
