SKU:TEL0051 with Arduino Uno not send message
Allan 2014-08-08 05:22:47 6549 Views7 Replies Hello
I am new to developing with Arduino,
But I'm doing a project for a university course,
I need to capture the current location and sends it via sms.
For this, I bought a GPS / GPRS / GSM Shield V3.0 (SKU: TEL0051) shield and an Arduino Uno.
I'm powering the Arduino with USB and a 9V supply
I used the examples described in https://wiki.dfrobot.com/tel0051
But I could not send sms or make calls.
DFRobot lights are on and the Serial Monitor can monitor the correct commands
Anyone know a solution?
Or problem that may be causing this?
2014-08-14 11:20:08 The problem was in S1
With your help, we can solve the problem
Thanks a lot
Now I'm trying to capture GPS data, if any questions appear I will return to post on the forum
Allan
Thanks a lot
Allan 2014-08-14 11:08:15 Thanks a lot Grey,
With your help I could send a message
But this shield not sending all messages
Seems to be "64ms On/ 3,000ms Off SIM908 registered to the network"
The CoolTerm shows the following result on the screen:
Allan
AT
AT
AT+CMGF=1
AT+CMGS="xxxxxxxxxxxx"
HELLO
Allan 2014-08-13 18:08:09 Network indication
State SIM908 behavior
Off SIM908 is not running
64ms On/ 800ms Off SIM908 not registered the network
64ms On/ 300ms Off PPS GPRS communication is established
Hey Allan,
Could you check the NET led? Is it in the state of "64ms On/ 3,000ms Off"?
What is your SIM card network? Does it support GSM network?
And have you tried AT command? please check How to send a SMS.
Grey.CC
Hey Allan,
Grey.CC 2014-08-13 09:39:03 Changed to:
S1: Prog, and turn to Comm after uploading;
S2: Arduino;
S3: Middle
But I still can't make the shield send a message.
I'm using this code:
Allan
S2: Arduino;
S3: Middle
Already tried several codes but none worked so far // Product name: GPS/GPRS/GSM Module V3.0
// # Product SKU : TEL0051
// # Version : 0.1
// # Description:
// # The sketch for driving the gsm mode via the Arduino board
// # Steps:
// # 1. Turn the S1 switch to the Prog(right side)
// # 2. Turn the S2 switch to the Arduino side(left side)
// # 3. Set the UART select switch to middle one.
// # 4. Upload the sketch to the Arduino board
// # 5. Turn the S1 switch to the comm(left side)
// # 6. Plug the jumper caps back to GSM side
// # 7. RST the board
// # wiki link- https://www.dfrobot.com/wiki/index.php/GPS/GPRS/GSM_Module_V3.0_(SKU:TEL0051)
byte gsmDriverPin[3] = {
3,4,5};//The default digital driver pins for the GSM and GPS mode
//If you want to change the digital driver pins
//or you have a conflict with D3~D5 on Arduino board,
//you can remove the J10~J12 jumpers to reconnect other driver pins for the module!
//Init the driver pins for GSM function
for(int i = 0 ; i < 3; i++){
pinMode(gsmDriverPin[i],OUTPUT);
digitalWrite(5,HIGH);//Output GSM Timing
delay(1500);
digitalWrite(5,LOW);
digitalWrite(3,LOW);//Enable the GSM mode
digitalWrite(4,HIGH);//Disable the GPS mode
delay(2000);
Serial.begin(9600); //set the baud rate
delay(5000);//call ready
delay(5000);
delay(5000);
Serial.println("AT"); //Send AT command
delay(2000);
delay(2000);
//Send message
Serial.println("AT+CMGF=1");
delay(1000);
Serial.println("AT+CMGS=\"xxxxxxxxxx\"");//Change the receiver phone number
delay(1000);
Serial.print("HELLO");//the message you want to send
delay(500);
Serial.write(0x1A); // sends ctrl+z end of message
delay(1000);
Serial.write(26);
while(1);
Allan 2014-08-13 00:04:00 I guess it caused by S1,
S1 is the switch of the Serial.
Prog: Cut the connection between module and Arduino, then you can upload the sketch
Comm: Make a connection between module and Arduino.
S2:
USB: Contact to USB port(AT command)
Arduino: Contact to Arduino
So if you turn S1 to Prog, Arduino can't talk with the module. Please turn S1 to Comm side after upload.
And which code are you using now?
Grey.CC
S2:
Grey.CC 2014-08-12 10:52:31 Thanks Grey,
It is powered by a 9V source
S1: Prog
S2: Arduino
S3: Middle
There are three LEDs
Power: On
Stat: On
Net: Switching
Sorry for the quality of pictures,
You know what is the problem?
Allan
S1: Prog
S2: Arduino
S3: Middle
Power: On
Stat: On
Net: Switching
Allan 2014-08-08 18:15:18 Welcome Allan,
It will be caused by many factors. Could you tell me further information?
Like:
What is power supply?
What is the position of three switch?
There are three led indicator, what is their status?
It is better to attach a photo about it.
Grey.CC
Like:
Grey.CC
