TEL0051 does not work with a simple code
pierrot10 2014-09-08 12:31:59 3496 Views3 Replies Good evening.
I just received the TEL0051 shield and I I am using it with Arduino Uno and a 7.4V/2000mA battery (Li).
In order to test it, I simply upload that simple code to test an AT command and what happen in Serial.
S1 is in 'prog' position
S2 is on 'Arduino' position
S3 is in middle position
I left all jumper J10-11-12 as it is
Why nothing happen?
[img]http://www.hello-web.net/temp/1.JPG[/img]
[img]http://www.hello-web.net/temp/2.JPG[/img]
After sending the "AT" command, I should read, at least, an OK in my terminal.#include <SoftwareSerial.h>
int baud_rate = 9600;
int pin_gsm = 3;
int pin_gps = 4;
int pin_power = 5;
//int pin_dtr = 6;
//boolean debug = true;
//boolean raedy_to_go = false;
Serial.begin(baud_rate);
pinMode(pin_gsm,OUTPUT);
pinMode(pin_gps,OUTPUT);
pinMode(pin_power,OUTPUT);
digitalWrite(pin_power, HIGH);
delay(3000);
digitalWrite(pin_power, LOW);
Serial.println(F("\nTurned on"));
gsm_enable();
Serial.println("AT");
if (Serial.available())
Serial.print("Character received: >>");
Serial.write(Serial.read());
Serial.println("<<");
void gps_enable(void)
digitalWrite(pin_gps,LOW);//Enable GPS mode
digitalWrite(pin_gsm,HIGH);//Disable GSM mode
Serial.println(F("GPS is enabled"));
Serial.println(F("GSM is desable"));
void gsm_enable(void)
digitalWrite(pin_gsm,LOW);//Enable GSM mode
digitalWrite(pin_gps,HIGH);//Disable GPS mode
Serial.println(F("GSM is enabled"));
Serial.println(F("GPS is desable"));
Why nothing happen?
2014-09-09 19:19:09 Yeah, module needs a little time to register SIM Card INF on the network.
And during sending AT command, it also needs a little delay.
Grey.CC
Grey.CC 2014-09-08 21:27:51 I change a bit my code by adding delay, and it return interesting value
pierrot10
// # Steps:
// # 1. Turn the S1 switch to the Prog(right side)
// # 2. Turn the S2 switch to the Arduino side(left side)
// # 3. Set the UART select switch to middle one.
// # 4. Upload the sketch to the Arduino board
// # 5. Turn the S1 switch to the comm(left side)
// # 6. RST the board
// # If you get 'inf' values, go outdoors and wait until it is connected.
// # wiki link- https://www.dfrobot.com/wiki/index.php/GPS/GPRS/GSM_Module_V3.0_(SKU:TEL0051)
//#define HWREAD;
int pin_gsm = 3;
int pin_gps = 4;
int pin_power = 5;
//int pin_dtr = 6;
delay(5000); // Wait for 5sec after begin
if(debug)
Serial.println(F("\n****************"));
Serial.println(F("STARTING SYSTEM"));
Serial.println(F("****************"));
Serial.println(F("Setting pinMode"));
pinMode(pin_gsm,OUTPUT); // Set the pins
if(debug)
Serial.println(F("Powering the module"));
digitalWrite(pin_power, HIGH); // Power the module
delay(1500);
gsm_enable();
if(debug)
Serial.println(F("READY TO GO"));
#ifdef HWREAD
serialhwread();
#endif
Serial.print("Character received: ");
Serial.println("");
if(debug)
Serial.println(F("Enabling GPS"));
delay(2000);
if(debug)
Serial.println(F("Enabling GSM"));
delay(2000);
pierrot10
