How I can connect both DF Robot LCD keypad schield and capacitive touch sensor
userHead paolodifalco@tin.it 2014-09-08 22:17:53 4610 Views2 Replies
Hi.
My name is Falcon.
I would like connect a capacitive touch sensor and DF Robot LCD keypad shield .
https://www.adafruit.com/product/1362
https://www.dfrobot.com/product-51.html
How can I connect this capacitive touch sensor with keypad circuit ( legs of the buttons)?
I would solder the wires, with output signals, directly to the legs of the buttons.
Can you suggest me the exact points where I can solder the wires to the legs of the buttons?
Thank you
2014-09-10 03:20:15 Yes, it is low.
Thank you for your help.
userHeadPic paolodifalco@tin.it
2014-09-09 20:13:14 Hello Falcon,
You mean you want to connect touch sensor output signal to LCD button?
As Analog Pin 0 is used to read the five buttons. I will attach the button Schematic diagram.
I am not sure what is the touch sensor output signal. I guess it should be "LOW".
If it is "LOW", you could solder it on the button leg directly, if it is "High", you need a inverting circuit, which could convert "HIGH" level to "LOW" level.
userHeadPic Grey.CC
