Two Mini Touch Kit (SEN0104) working with one pin on Arduino
Masouras Michalis 2016-07-31 07:01:55 2266 Views3 Replies How can I connect two mini touch kits on a single pin?
2016-08-01 22:47:02 Hi Masouras,
Did you test the sensor seperately? And they are working, right?
And could you provide me some code of your project?
Wendy.Hu
Wendy.Hu 2016-08-01 22:11:56 I try the connection on the diagram but is not working.
The project is to switch on/off a light from two different positions.
Masouras Michalis
Masouras Michalis 2016-08-01 18:31:58 Hi Masouras,
You can directly lead to 2 lines at the end of each pin, then the rest of the three lines connnect to three pins of the other board: Digital pin, VCC, GND
Wendy.Hu
Wendy.Hu
