Avrdude stk500_recv - Problem APC220
Account cancelled 2016-08-23 16:24:44 1808 Views1 Replies Good evening fellow
I have a problem in APC220 , I can not make it work in any way , all connections are correct , rx -tx tx- rx , 5v and gnd .
Both adapters are using the same parameters in RFMagic .
I use an Arduino UNO R3 ( ATmega328 ) .
When compiling the file the IDE presents Loading ... however the error as image.
I'm unplugging the rx to compile.
I appreciate the attention and I'm waiting !
Sorry my english , I'm from Brazil and I am using translator
2016-08-23 23:07:20 Hi lwalkiu,
When uploading the code, you need to unplug the TX and TX, since the TX and RX would be occupied. After done uploading, plug the TX and RX again. There is a note in the wiki: Arduino IDE 1.6.5 cannot display the message at all, we recommend using Arduino 1.0.6 serial monitor or an alternative serial monitor, maybe you need to download 1.0.* IDE.
Please make sure the board and com port you chose is right.
Wendy.Hu
Wendy.Hu
