Turbity sensor not Working
userHead jcry.silva 2016-09-24 13:58:44 3676 Views8 Replies
I have a DFRduino UNO R3 with an DFRobot LCD Keypad Shield 16*2 plus Turbity Sendors.
I can't have it working. I just receive the value 0.04.
Is that normal? There is one way to calibrate the sensor?
Or maybe some lines on the code missing?
Thanks for the advices
2016-09-30 22:16:41 Open the shell of the probe, the white one, there is a metal zero potentiometer. try adjust, its should show some difference.
If there is still no change, probably the sensor is a defective one, under the warranty, you can go to our return page to require a replacement, the page link as follows:
make_clickable_callback(MAGIC_URL_FULL, '
', 'https://www.dfrobot.com/index.php?route=account/return/insert', '', ' class="postlink"')
Note: since our website is updating, the post page will be some change, just copy the link address to search.
userHeadPic Wendy.Hu
2016-09-30 10:40:15 Yes, I know that. userHeadPic jcry.silva
2016-09-30 02:41:07 Can you give a picture about your diagram? Did you notice the D/A switch? When you connect the sensor to analog, please toggle the switch to A; when you connect to digital, toggle to D. userHeadPic Wendy.Hu
2016-09-28 05:42:44 I did it, same problem.
I tried another sensor, same problem.
2016-09-27 22:22:18 Oh, maybe I know the problem. Please modify the code to :
int sensorValue = analogRead(A1);
The A0 port on the shield has been occupied, then you connected to analog 1, but dont modify the code. Please try again.
2016-09-27 03:39:19 The code:
Serial.begin(9600); //Baud rate: 9600
int sensorValue = analogRead(A0);// read the input on analog pin 0:
float voltage = sensorValue * (5.0 / 1024.0); // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
Serial.println(voltage); // print out the value you read:
Delay(500);
And the sensor is connected tu Analog1 on the dfrobot lcd shield that is connected on the dfrduino.
2016-09-27 00:34:15 Hi Sir,
Whats the voltage value you got? 0.04? Did you notice the "D/A" Output Signal Switch when you used different mode? Can you provide me some pictures about your code and the diagram? Whats more, the sensor no need to calibrate.
2016-09-26 10:16:43 Someone can help me there? userHeadPic jcry.silva
