Error AT Commands testing GPS/GPRS/GSM MODULE V3.0
userHead cortega 2017-01-26 05:10:24 2072 Views3 Replies
I am trying to drive the module via USB port (AT commands). I use Coolterm software and I have followed all steps in your tutorial from dfrobot.wiki.... However, the answers due to my AT commands are very stranges.
For example, to command "AT", Coolterm shows me as answer: )-hø
I dont know what can be the problem....
The code is the following:
//Init the driver pins for GSM function
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
//Output GSM Timing
digitalWrite(5, HIGH);
delay(1500);
digitalWrite(5, LOW);
digitalWrite(4,LOW); //Enable GPS Mode
digitalWrite(3,HIGH); //Disable GSM Mode
//digitalWrite(3, LOW); //Enable GSM Mode
//digitalWrite(4, HIGH); //disable GPS TX、RX
PWR is on, STAT is on and NET is turn on/off constantly.
S1: Comm, S2: USB and S3: GSM
I really appreciate any help you can provide. Regards ;)
2017-02-09 19:53:44 Hi
It sounds strange. Did you try to test the other function like sending a sms, making a phone call? Then does the module work? Did you set the baud rate to 9600?
userHeadPic Wendy.Hu
2017-02-08 00:35:09 Of course, SKU:TEL0051 userHeadPic cortega
2017-02-03 23:30:11 Hi cortega,
Sorry for the late reply, since the Spring Festival.
May I know the sku of the module? Since we have several this kind of modules.
Looking forward to your reply. :)
