DFPlayer Mini Plays only the first song
edjong 2017-01-27 02:46:04 2811 Views3 Replies I would like to use the DFPlayer mini as an USB player with the use of only 3 keys:
Key 1 = pause/play
Key 2 = prev
Key 3 = next
The problem is that the player does stop after playing the first song while it must go on with the following song.
Does anybody knows how to solve it.
Key 1 = pause/play
Key 2 = prev
Key 3 = next
2017-02-04 19:41:00 Hi
Are you using the AD key mode, right? If yes, according to the diagram, the resistance between the two function-Loop All and Pause is different. It is to use the principle of resistance divider to achieve the corresponding functions. The resistance value should be 33k, right?
Wendy.Hu
Wendy.Hu 2017-02-01 00:42:31 When I use Loop All then it will go further to the following song, but I can not use the Pause function with the same switch.
With another USB player this was possible, but I prefer this one because it is very compact and you can put it directly on a PCB.
edjong
edjong
