Ultrasonic sensor for the measurement of dimensions (HхWхD)
userHead Account cancelled 2017-01-27 22:31:38 1421 Views1 Replies
We need to accurately measure the size of the box. Recommend ultrasonic sensors for accurate measurements, please. Now we use sensors URM37 ver.4.0.
All right, but there is a problem ..
If we measure the length of the box located between the two sensors, the sensors are not working properly.
2017-02-04 01:23:34 Hi
Sorry for the late reply.
If I understand correctly, do you want to measure the size of the box located between the two sensors via the two sensors, right? If yes, maybe there are some difficulties. Since the two sensors will interact with each other.May I know why do you want to do this?
userHeadPic Wendy.Hu
