GSM Shield says message send but doesn't receive
tamy 2015-02-09 06:55:32 3967 Views3 Replies Hi, I'm using a gsm shield to send SMS messages, and I'm literally on the first step with the info at
I used this code :
Code: Select all #include "SIM900.h" #include <SoftwareSerial.h> #include "sms.h" SMSGSM sms; int numdata; boolean started=false; char smsbuffer[160]; char n[20]; char sms_position; char phone_number[20]; char sms_text[100]; int i; void setup() { Serial.begin(9600); if (gsm.begin(9600)) { Serial.println("\nstatus=READY"); started=true; } else Serial.println("\nstatus=IDLE"); if(started) { if (sms.SendSMS("+300000000000", "Arduino SMS")) { Serial.println("\nSMS sent OK."); } else { Serial.println("\nError sending SMS."); } } }; void loop() { if(started) { sms_position=sms.IsSMSPresent(SMS_UNREAD); if (sms_position) { Serial.print("SMS postion:"); Serial.println(sms_position,DEC); sms.GetSMS(sms_position, phone_number, sms_text, 100); Serial.println(phone_number); Serial.println(sms_text); } delay(2000); } };
When I first started .. the code runs in the case of a transmitter and receiver, but now can not receive .
pls help me . :'(
we also have Controler based on SIM900, but never met this before.
so is it working all right now?
Leff On actuation sender .. But when you reach the messages appear to me ( SMS postion:-2 )
tamy
Grey.CC
