DFROBOT WiFi Shield V3 Help.
userHead Account cancelled 2017-06-02 21:21:26 2490 Views1 Replies
So, I recently purchase this wifi shield from here: https://www.dfrobot.com/wiki/index.php/WIFI_Shield_V3_PCB_Antenna_SKU:TEL0078
I followed the manual to try and get it to work, but cannot get something right. When I search for the wifi signals, I don't see DFROBOT_WIFI_SHIELD_V3 anymore. I only get the USR-WIFI232-G2 signal now. I think I followed the tutorial I linked above correctly to get AP+STA mode working. Anyways, when I first got this shield, I did see the DFROBOT_WIFI_SHIELD_V3 signal. I eventually held onto the reset button for 3 seconds to factory reset it, since I couldn't find that signal anymore and thought this would help out.
Is there anyone that can help on this type of situation? I tried using the USR-TCP232-Test RS232 to Ethernet Convert tester software they suggested to test out the connection, and I can't send anything to the Arduino board. I'm assuming it's because I can't find that specific wifi signal anymore. I can send stuff to the TCP-Server, though.
2017-08-19 12:28:36 I also did several configuration tests, but without success. With the USR-TCP Tester software I can not receive the data from the WIFI module. I can pass them on. However, when I transmit data from the serial port to the WIFI, the data is received on the serial port and simultaneously on the WIFI module. Why do I not reproduce the data only on the opposite link? From Serial to WIFI. By passing why the AT commands do not work with PUTTY? userHeadPic lesalain2010
