Red led blinking, reset loop
cyberluke 2016-06-02 01:03:42 3880 Views4 Replies Hi, I got the same problem with getting stuck at "Just a moment" loop after first time power on. I read other thread that I should use recovery reset and reinstall Windows. Everything went well, copied to 100%.
But now nothing loads, cannot access BIOS and RED LED keeps blinking all the time. I can power on, reset Arduino, reset PC...but that's it. I tried to put USB flash WINPE image into USB 3.0, but it won't go to installation procedure.
Tried also 3A power supply, read all the forums...anything else that I could overlook?
Thank you!
Thank you!
