HowTo: Power your LP without using microusb
Relampago 2016-06-20 14:33:02 7858 Views7 Replies I want to legt you guys now, that it is possible to power lattepanda through any 5v connector.
I am now using a non USB 5,2 3A power supply to power lattepanda on connector 6.
In addition I did some current measurements.
Boot: round about 1A
Windows usage: 1.2A
Furmark: At start 2.8A than 1.9A
Cs go: 2.1A
GPU-z Test: 2.1A
As a side note, with a 2A USB power apply, the lattepanda shutdown when I was starting furmark. Starting gpuz test with 2A power supply let to a throttling of all cores to 480 MHz. There seems to be a low current mechanism in the atom.
Windows usage: 1.2A
Cs go: 2.1A
GPU-z Test: 2.1A
