[RESOLVED] can't use touchscreen, install wifi antenna
frantic horse 2016-07-04 08:10:18 6240 Views9 Replies Hi
My lattepanda which i just discovered today has 2 problems only so far
*i cant knstall the wifi antenna, the plug on the antenna seems to be not wide enough to fit on the board clip ! Am i the only one ? Should i force or can i try to widen the thing ?
*the touchscreen doenst seem to work. I plugged it in the adequate port of the board, and i usedthe ducttape on it to glue to the screen, but nothing happense when i touch the screen. Need i install drivers ?
Thanks in advance
Thanks in advance
