Turn off blue LED (Arduino pin 13)
userHead LattePanda 2016-07-29 19:55:36 4411 Views3 Replies
The blue LED on your LattePanda is actually the Arduino's pin 13 LED. If you don't like it flashing you can disable it by uploading a blank Arduino sketch like so:
void setup () {} void loop () {} If you do like it, you can also play with different flashing and fade sequences, such as the "fade" example in Arduino IDE
Hope this helps
