[TUTORIAL] LattePanda Bios Reflash Save LP from red light .
userHead Zzz5123 2016-08-09 04:52:55 169269 Views88 Replies
For those who have the same trouble
In this tutorial I will show you how to flash a bios chip. The bios can become corrupted for numerous reasons and prevent the board from booting. Usually this is what causes the “red light on no boot issue”. This will save your board!
What you need is a Bios programmer/writer with software
And furthermore, this tool can also use to back up/copy the Bios original code. That means you can change the bios setting or hacking without worrying, ha-ha.
Let’s begin.
First, unplug all the cables on the board!
Step 2
Remove the shield cover.
The chip is on the back side, and LattePanda has a cover on? It. 1.jpg 1.jpg (124.55 KiB) Viewed 47864 times By the way, you can see the purple thermal pad used in LP. No judge,LattePanda Team, but add some thermal paste or change to a higher thermal conductivity would be better. 2.jpg 2.jpg (21.93 KiB) Viewed 47864 times
