[Defective] 4g/64gb Wifi Code 10 will not start
sgroenink 2016-08-26 11:47:45 2589 Views1 Replies I have an enhanced 4g/64gb that worked great for 24hrs after I got it set up and then the wireless quit and give me code 10 device cannot start. it is powered via the 5v adapter and usb cable supplied with the unit when I received it
I have reimaged using the LP provided 4G/64bit image from the site with exact same code10 message, I have tried the asus EE tablet drivers, I have tried the wifi drivers from the lattapanda google drive with zero difference
I will require an RMA for either a refund or a replacement unit. You can search through the forums here and can see my struggles without any progress
Steve
Steve
