Is it possible to have high speed IO connection to the CPU?
assadij 2016-08-29 18:12:53 2492 Views0 Replies Hi,
I have an 8bit, 6.25M Bytes/sec connection that I want to get the CPU to read the data and process it, or record it on the microSD card.
What is the best way to connect this to the processor?
U1 connection seems to be an I2C bus which can't go fast enough.
I can produce a 50Mbps serialized data instead of the 6.25MBps if there's a way of getting processor to connect to the signal.
Thanks in advance,
James.
Thanks in advance,
James.
