[DEFECTIVE] TF slot frequently not working
userHead reizhi 2016-09-13 06:09:30 7918 Views8 Replies
I'm using standard edition,but tf card slot frequently not working from the first time I was insert a tf card in it.
The issue is:when i plug in the tf card,7 out of 10 times it won't recognize.Even if it has been mounted,when I tried to read or write some data to it,still has some chance to get stuck.
More seriously,even if it works well,and I just reboot the system without touching the board,the card reader icon inside my computer could disappear!
This problem could be temporary fix by plug in and eject it several times.
I've installed all drivers you provided since os reinstall.This card is a new one and works well in USB card reader. Attachments 2016-09-12_220834.jpg 2016-09-12_220834.jpg (204.02 KiB) Viewed 7110 times 2016-09-12_220419.jpg 2016-09-12_220419.jpg (214.8 KiB) Viewed 7110 times
