Flip Lever for Touchscreen connector broken
userHead JHornbr225 2016-09-14 04:42:14 7338 Views11 Replies
I've had my LattePanda for a little while now, but I finally got my case built and assembled. I had a friend print me http://www.thingiverse.com/thing:1605660. I modified it slightly to hold a larger, easier to get fan (60mm). I also used a 10mm heatsink instead of the 20mm one called out by the creator. He also printed me a http://www.thingiverse.com/thing:1564765. I put my screen in it, pulled the adhesive backing and attached the LattePanda touchscreen. I thought I was all set. when I attempted to latch the lever for the touchscreen cable, the lever broke off. The lever for the display connector seems more robust, as it's a larger connector, but the touchscreen one is very fragile. I can put the cable in, but without latching it, the touchscreen is not recognized.
Is there any way to get this fixed?
