The never stopping fan
userHead gnusi 2016-10-01 06:18:18 8680 Views2 Replies
So I purchased this fan from DFRobot https://www.dfrobot.com/index.php?route ... ct_id=1520 since I was having trouble with my panda after watching stream services on my TV for a while. CPU throttling and heating problem most likely.
After I installed the fan it started to run immediately after the lattepanda was plugged in to power even though the lattapanda itself wasn't turned on. So everytime I turn the lattepanda off now the fan just keeps spinning until I disconnect the lattepanda from electricity. Is this normal, is the fan supposed to be working all the time even if the board is turned off?
