Bluetooth and metal case
jolo 2016-11-08 10:42:38 2376 Views1 Replies Hi all!
I plan a project that uses LP to control astronomy imaging setup. I would love to have aluminium case for the final product, but on the other hand I need both WiFi and BT working. So my question is - where is BT antenna? Is it only internal, so using metal case will prevent BT from working? Or WiFi antenna works also for BT, so it can be placed outside the metal case?
Thanks in advance
Lucas
Thanks in advance
Lucas
