lattepanda doesn´t boot (red led is blinking)
userHead ReDTrucK 2016-11-27 07:45:07 3255 Views3 Replies
I have the standard version and i had the lattepanda for two months. I use the recommended power supply and the cable.
When i apply power the blue and the red led start blinking. After a few seconds the blue goes off and the red led is still blinking. After 5 minutes it did´t stop. If i press the "system start button" long enough the red led will go off and if i press again it starts blinking again.
Thank you for your help
