Touch panel behavior
userHead werner 2016-12-20 23:46:29 2515 Views2 Replies
I`ll use my LP for the controll of a CNC Mill.
I`ve downloaded the control SW succesfully, but there is one problem.
When I would like to move an axis manually, I can move it, when i have the cursor of the mouse pressed on the button.
But with the touch panel this does not work. The axis moves only a small increment every time i touch the button. leaving the finger on the button to move continuously doesn`t work with te touch panel
Are there any settings for the touch panel where I can change this behavior?
regards Werner
