FirmataWebClient
Giandomenico 2018-08-11 06:56:47 1557 Views0 Replies Hello,
I have tried to use the FirmataWebClient with NodeJS but when I tried to set a simple Digital pin (the LEd on D13), the answer message after the command "node set_digital.js" is :
error: connect ETIMEOUT 192.168.2.37:23456
What appends ?
Other question : what kind of firmware should I have to install on the Arduino for the FirmataWebClient ? LattePanda.Firmata ? Correct ?
Thank you very much for your help
Regards
What appends ?
Regards
