[SOLVED] LattePanda with Ubuntu Image freezes with WiFi on
lucas.baiao 2018-10-09 05:58:03 3808 Views3 Replies Hi Guys!
I've been using Lattepanda with Ubuntu for two weeks now, I had some issues, nothing big at all, but since the first day that I've been using, my Lattepanda is getting freeze ramdomly, there is no mouse or keyboard response and neither the clock moves. I tested some things and the only one that makes some diference was turning off the Wi-Fi. With Wi-Fi off the system works well... There are somethin that I can do to try to update Wi-Fi drivers or anything else?? I'm using the standard hardware (2GB/32GB)
Thank You,
Lucas
Thank You,
Lucas
