AUDIO Driver refuses to install URGENT
nomissivraj 2018-12-19 18:26:15 1928 Views1 Replies Hey,
I'm having trouble installing the Realtek I2C Audio Codec/driver and can't get any microphones to work with the LP at all. USB or 3.5mm jack.
This is urgent as I need this to work for a final year University module for which the deadline is only a couple of weeks away.
Every time i install either through windows automatic online search or manually using the official 2G32GB_Drivers release. Including via cmd (administrator mode) it always fails to install saying that the driver 'is not intended for this platform'...
It shows up as Unknown device:
This is what i get with every method to install the driver
Then once it's failed it get's moved to the Other devices section
I'm at a loss for what to do... i don't even know if this will fix the issue with no microphones being recognised.
EDIT: Have managed to find a USB microphone that works with the LP. However I'd still like to rectify the driver situation and work out how i can use the 3.5mm jack as the microphone for that is much smaller and better for IoT implimentation.
Please help!
Thanks,
Simon
Please help!
Thanks,
Simon
