External power button
dmanlfc 2019-01-10 23:18:23 5142 Views5 Replies Can I assume an external two wire power button can attach to the SW header on the Alpha to power on the SBC?
I will be mounting the Alpha 864 into an arcade cabinet, so therefore want to ensure with a toggle switch I can turn the SBC on / off with ease.
I will likely be using Ubuntu 18.10. On toggling to the off position, can I assume the SBC will gracefully shutdown?
Dan
Dan
