New Touch Panel for Alpha PROBLEM
userHead Sebek 2019-01-15 13:59:45 18843 Views23 Replies
I have a problem with the touch panel. The first thing I did was remove the already installed windows 10 and installed my own. Unfortunately, but the touch panel doesn't work, now I don't know if it is the fault of the panel itself or maybe I don't have any drivers in the system. However, I suspect that I don't have drivers because I miss something, I found out on my own that it could be a touch panel driver. Can I ask for correct touch panel drivers? The touch panel also does not work on the phoenix OS.
Thanks in advice!
Greetings Sebek
