Fail to power Latte Panda 4/64GB from CN2 headers with Meanwell DIN rail power supply
userHead Morgennebel 2019-01-18 08:21:00 2980 Views1 Replies
Dear,
I have a Latte Panda 4/64GB running fine with Devuan Linux (www.devuan.org), e.g. shows Latte Panda symbol before booting, offers grub bootloader, starts into Linux.
The Panda is running fine using a USB power supply offering 5V@3A and using the small USB port.
However it's not booting when using the CN2 headers and a Meanwell DIN rail power supply providing 5.01V and maximum of 6.5A (https://www.amazon.de/Hutschienen-Netzt ... B00MWQEGSC). According to specs the power supply requires 100msec to boot up and 30msec rise time.
Blue LED is, dims up bright on twice within about 1/2 secondRed LED is onBoth LEDs are darkPattern repeats
There is never a Latte Panda symbol, the monitor remains black and the system never starts. Voltage has been metered and adjusted to 5.01V. No cables are changed.
As I would like to use the Latte Panda within an Industrial Control environment and within a closed DIN-rail based case I would much prefer the DIN rail power supply over an USB power supply which prevents closing the lid.
Any ideas why the Panda would not boot up giving a much stronger power supply? Hard Reset has been completed already.
Thanks, -MN
