Second Reset Pin
pieterk 2019-01-29 07:01:46 3435 Views2 Replies Iv been working on a watchdog application that checks that a windows app is running, if the app stops working then the arduino side of board will reset the latte panda by activating the reset switch which is attached to pin 10.
in order for me to be able to use this setup i had to remove the reset switch and weld a wire into the tracks of the switch, so i was wondering if there is any other point on the latte panda where i could possibly pick up the reset switch with out taking off the actual reset switch.
