Questions for Battery Management.
invi 2019-01-29 21:07:47 4214 Views9 Replies Hi.
I trying connect battery to a LP Alpha. but, does not find any board information data & reference for battery connection.
I don't understand and don't know how I connect for the "10p connector" in LP Alpha.
So, I don't know how I designed the "10 pin connector" as you.
Some Questions.
1. Is contained the "Battery Management Chip" in the LP Alpha?
2. What is the correct use of "4-pin power connector" and "10-pin power connector"?
3. If you designed the "10 pin connector", you would have designed it with some intent, but why have you put off the disclosure yet?
4. This board has a total of three power inputs (including USB-PD).
Knowing how the 'power inputs' of the "LP Alpha" are configured and how they work, battery configuration and battery circuit design are possible. So, Can you disclose of the data or guide me on this?
Thank you for the efforts .
Some Questions.
