LattePanda 4GB+64GB (CR200 z8350 ) shutdown randomly
userHead ewaca 2019-01-30 01:35:40 2227 Views0 Replies
My board shutdown (black screen) randomly (5min, 1 hour ... after boot) while idle or not
i have almost tried all you suggest to resolve issues :
- i have tried many power supply and cable (2.0, 2.1, 3.0 Amp with micro usb)
- i have tried to power through CN2 header with my odroid XU4 power supply (4.0 Amp)
https://www.casimages.com/i/190129101833991086.jpg.html
https://www.casimages.com/i/190129101831705687.jpg.html
- i'm using a cooling solution (temp is about 55/60° when it crashed)
-i have tried to reinstall drivers many times
-i have tried to flash bios (Default and ubuntu ones)
the 2 things i have not done :
-reload OS : i have a BSOD when it boot on iso : https://www.casimages.com/i/190129101845495916.jpg.html
-flash bios at hardware level
i have this board from saturday, it always crashed, i guess it was power issue, but now i don't think so. With my odroid XU4 power supply, i can't run the XU4 for days with all cores at 100% and i have no problems.
so ... what should i do now ?
