hard drive is no longer seen in bios
Alexand 2019-02-17 04:00:26 3013 Views7 Replies after removing linux ssd, nvme is no longer defined in bios. You can only see its section marked "uefi: built-in EFI Shell". In windows, only 220 gb out of 240 is defined. The data on the disk is not important, so if there are options to delete all data, etc. - come down
