LP Alpha's USB-C port
LXP 2019-03-19 02:01:17 3140 Views5 Replies Hi there,
for the experts, this might seem like a silly question:
Is it possible to use the LP Alpha's USB-C port to do the following things SIMULTANEOUSLY:
Obviously enough, some sort of hub would be necessary. Has anyone found something to do that trick?
Thanks in advance,
LXP
- Power the LP Alpha, preferably but not necessarily via the included power supply
- Power an external touch display via its USB-C port; https://magedok-shop.myshopify.com/coll ... nitort116c
- Transfer video/audio/touch data between the LP Alpha and the display
Thanks in advance,
LXP
