Recommendations for optional M.2 Wifi/BT card for LattePanda Alpha
userHead bioan 2019-03-30 00:43:04 2506 Views2 Replies
I struggle to construct a very compact case for my LattePanda Alpha board and I don't like the external Wifi/BT antenna cables provided by default.
I would like to use an alternative card mounted in the additional M.2 e key slot on the back of the board to avoid any wires. Which could be the best (fastest) and compatible solutions for accesing Wifi/BT with the LattePanda alpha board?
Thank you!
Ioan
