How to turn of USB Power when device is switched off
slop 2019-04-04 07:42:37 6707 Views4 Replies Hi
I build a mobile Emby Server with my LattePanda alpha. I have a little Box with a USB-C Battery, a little Router and the Alpha. The Router and a FAN are pluged in by USB.
The Plan was: switch off the Apha= everything turned off.
But the Fan and the router are still powered via USB when the Alpha switched off and the battery is connected.
Is it possible to disable USB power, when the Panda is turned off?
