Fitting the LattePanda into 3.5" drive bay?
userHead jason 2019-06-15 00:41:38 2829 Views1 Replies
According to the site the LattePanda Alpha/Delta has the following dimensions
115mm x 78mm x 14 mm and the 3.5" form factor is 147mm x 101mm x 19mm - 26.1mm
So it should fit into that space I was wondering if anyone has attempted this? Is there already a way to mount this in a 3.5" slot available? (not seen anything)
I am thinking of making a 6 node docker cluster (docker swarm or kubernetes) into an old NAS style PC case (https://www.fractal-design.com/home/pro ... x-nas-case).
