Bluetooth driver for Alpha 864s
Vetinari 2020-02-28 01:36:53 7219 Views4 Replies Hello,
I made a fresh Win 10 Pro installation. The Microsoft Driver Support Assistant installed an Intel Bluetooth driver but the Bluetooth peformance is very bad. Sitting directly in front of the Alpha the connection to a bluetooth headset shows a kind of on-off behaviour (tested with a COULAX Bt 4.1. headset and AirPods 1. Gen Bt 4.2)
Is this a driver or an antenna problem?
Is it helpful to use an external M.2 Broadcom card? If yes, which one should I buy?
Martin
Martin
