Arduino digital output does not work
t157 2020-03-13 20:52:51 4746 Views2 Replies I'm using two LattePanda 4G/64GB with Windows10.
One Arduino uses 1.8.10.
Another Arduino uses 1.0.6. (original)
I have a problem with Arduino digital output.
Digital output does not respond even if the following code is executed.
The operation is the same for both Lattepandas.
pinMode(7, OUTPUT);
digitalWrite(7, LOW);
delay(500);
digitalWrite(7, HIGH);
delay(500);
Pin No.7(D7), 9(D9) are NG.
but, Pin No.10(D10), No.13(D13) are OK.
No.13's LED is blinking.
am I forgetting any settings?
pinMode(7, OUTPUT);
delay(500);
delay(500);
