Alpha/Delta Ethernet
cloudst 2020-05-29 11:32:56 1724 Views2 Replies Which network cards are in use on the Alpha/Delta? (by extension also for the other models) The specification only states "Gigabit Ethernet", i need specifics. RealTek? Intel? Which version/Product name? Is it a true PCIe module or some kind of USB-Eth converter as with the older models (I have one from the first kickstarter batch. The ethernet is set up via a realtek controller on USB Port 4 for those)
Reasoning behind the question: I need the board as a mobile board for Windows kernel development/debugging and only certain vendors/devices are supported for that. (https://docs.microsoft.com/en-us/window ... windows-10)
I would appreciate any feedback / datasheets on the matter that i missed
Best regards,
cloudst
Best regards,
cloudst
