[RESOLVED] Can't turn on LattePanda Alpha
kchen-rugged 2020-06-25 10:39:15 1420 Views2 Replies I powered on the LP board for the first time two days ago and successfully installed Ubuntu 18.06 LTS. I've been able to power on the board and ssh into it up until this morning.
The board is connected to the stock power supply and has no additional peripherals attached. Once the power supply is connected, the LEDs blink in a RED - BLUE - DIM RED pattern. Pressing and holding the SW button doesn't do anything and the LEDs continue to blink in the same pattern. Video here: https://vimeo.com/432251052
What might be causing this issue? How can I get the board to power on again?
